enable mirror
enable mirror mirror_name
Description
Enables a mirror instance.
Syntax Description
mirror_name Specifies the mirror name.
Default
Disabled.
Usage Guidelines
Use this command to enable a mirror instance. An instance may be enabled without source filters defined (per current function), but no traffic will be mirrored until source filters are added.
The following example enables a mirror instance named "mirror1" :
enable mirror mirror1
This command was first available in ExtremeXOS 15.3.
Platform Availability
